pullin the wheel
Old Nov 9, 2007 | 08:04 PM
BIGRED97's Avatar
BIGRED97
Default pullin the wheel
Im pulling the steering wheel in the morning in order to replace my clock spring. i printed and read the info out of the downloaded manaul. im just looking for some experienced information. anything will be helpful! thanks
Old Nov 17, 2007 | 03:10 PM
BIGRED97's Avatar
BIGRED97
Default RE: pullin the wheel
whats the trick to pulling the retaining nut in the center of the wheel? its a PITA!!
Old Nov 17, 2007 | 03:27 PM
Sirhilton17's Avatar
Sirhilton17
Ive had mine off... Its simple.
I just used a socket (i dont remember waht size) got the nut off of there, then used a puller to pull the wheel off the shaft.
You dont have to use a dedicated steering wheel puller, but they do make pullers specifically set up for pulling steering wheels. You could get the wheel off without a puller, but I dont recomend it. Im sure you could rent a puller from autozone if you dont already have one.
Old Nov 17, 2007 | 03:44 PM
BIGRED97's Avatar
BIGRED97
yeah i got the puller. i just cant get the nut. did you do by yourself? my socket keeps slipping off because my wheel is not locked so it just rocks back and forth as i pull down on the wrench.
Old Nov 17, 2007 | 04:12 PM
XXL 1500's Avatar
XXL 1500
impact that bi*ch!
or use a pry bar wedged downward somewhere...
lol puller...
i finally bought one after i yanked one out at work and hit myself... haha
oh and make sure you have battery disconnected on the negative side!
Good Luck!
Old Nov 17, 2007 | 05:34 PM
BIGRED97's Avatar
BIGRED97
i got it! my roommate came home so i had hold the wheeland i got it off with like 1/4 of a turn. and now everything is back together. new clockspring works and the airbag light went off and i avhe cruise control again!!
i was gonna use an impact but my bro has the air compressor... oh well im to strong for an impact!!! haha
now to return the puller to autozone
