Sweet-cricketts,.. How do you get to the,..
Old Nov 11, 2007 | 02:09 PM
JBs DAK's Avatar
JBs DAK
Default Sweet-cricketts,.. How do you get to the,..
Thermostat housing and bolts to replace the thing??
It looks to be about a mile and a half down into the bowels of the motor
with everything the engineers at Mopar could put on top of it in the way!!!
I've got a new housing, a new 180 thermostat but, any tips on getting to it?
(It's seeping)... '96 with air. 360 motor. 4x4.
Old Nov 11, 2007 | 02:15 PM
XXL 1500's Avatar
XXL 1500
Default RE: Sweet-cricketts,.. How do you get to the,..
3/8's
6-12" extension
13mm mid-depth
whatever ratchet
then carefully remove thermostat housing assembly.
then cut off the damn "DURRR FRONT DIS WAY -->" tab
or you can remove alternator and make it a little easier... but more time consuming
Old Nov 11, 2007 | 02:31 PM
JBs DAK's Avatar
JBs DAK
Thanks, I'll try to get that thing done tomorrow after work.
Grind the Tap-thingy off,.. I'll remember that.
Old Nov 11, 2007 | 02:40 PM
rabbler's Avatar
rabbler
I always glue the gasket to the housing with a bit of RTV just so it doesn't get mis aligned.
Old Nov 11, 2007 | 04:04 PM
XXL 1500's Avatar
XXL 1500
ORIGINAL: rabbler
+1
me too
Old Nov 11, 2007 | 08:22 PM
rango726's Avatar
rango726
just did that his weekend i wish i thought of grinding that tab off though it made it a bitc# to get it out. and putting it back on sucke# too over all not diffacult just irritating
Old Nov 12, 2007 | 06:56 AM
JBs DAK's Avatar
JBs DAK
Glue? What do you mean glue?? RTV Black???
And, should I replace the clamp for the hose while I'm
messing around down there? There's no rust or anything on it
but, it IS 12 yrs old. Thanks you guys for answering stupid questions.
Old Nov 12, 2007 | 09:24 AM
Sixtysixdeuce's Avatar
Sixtysixdeuce
I actually find it easier to take the belt off the A/C clutch pulley andunbolt the A/C compressor and lay it to the side. It's more R&R, but that way you can prperly clean the sealing area on the manifold and be sure that you've got the T stat and gasket aligned so that the housing is sealed. It takes a little longer to do it this way, but less time than doing it twice. Just my $0.02.
Old Nov 12, 2007 | 04:32 PM
mr freeze's Avatar
mr freeze
I had to do it three times before I got it to seal.I didnt want to remove all that stuff so I guess laziness got the best of me.Whatever happened to those tstats you just drop in the radiator fill cap.Those were nice.
Old Nov 12, 2007 | 04:37 PM
shott8283's Avatar
shott8283
i removed the alt too
becarefull tho.. you have a coolant temp sensor stickin out right near where your working and if your not cautious,, you can break it off like i did..
like someone said above.. grind that retard tab off ..and it ill come out easier next time.. AND like someone else said above.. tack the gasket inplace with some RTV and it wont move when you stab the stat housing back into place!
