exhaust manifolds loosening up
Old Nov 11, 2007 | 08:30 PM
rango726's Avatar
rango726
Default exhaust manifolds loosening up
i did a coolant flush this weekend and went with the 180 t stat and it made a pretty good difference. i love these cheap mods. but anyway i noticed my exhaust manifolds keep loosening up. ive used loctite before and it didnt hold any ideas
Old Nov 11, 2007 | 10:14 PM
greenmachine's Avatar
greenmachine
Default RE: exhaust manifolds loosening up
Stock or modified? How did you use the loctite?
Old Nov 11, 2007 | 10:30 PM
steve05ram360's Avatar
steve05ram360
there is a locking nut or bolt setup out there but I've never used it. check with Summitracing.com and see what they have.
Old Nov 11, 2007 | 11:17 PM
BlueBeast2's Avatar
BlueBeast2
yeah summit has locking header bolts the set is like 46 bucks though. I think I'm just gonna use some lock washers
Old Nov 11, 2007 | 11:35 PM
steve05ram360
are these the studs coming out of the heads or the bolts?
Old Nov 11, 2007 | 11:45 PM
rango726's Avatar
rango726
there bolts. the heads were replaced by the dealer when i bought it so im sure thats why this all started. as far as the loctite ive done it twice but i make sure the motor is completely cool then i take one out at a time apply it to the threads and then reinstall. i dont use the truck for roughly 12 hrs after just to make sure it cures. but i also dont want it to seize in there. i considered the locking washer idea. and $50 is expensive for bolts granted i may not have much of a choice. oh and the truck is stock other than the tps mod and a 180 t stat but thats really arent what your talking about as far as modified im sure.i plan on going with headers when i have to do my exhaust but until my exhaust goes it will stay as is.
Old Nov 14, 2007 | 12:51 AM
bill022572's Avatar
bill022572
Had this same problem with mine after I replaced my cyl heads. Well, actually only on one head but anyway : what I did was get all brand new bolts and studs and nuts and washers from the dealer and new Fel-Pro gaskets from NAPA and put it together with loc-tite and haven't had any further problem.
