TWO THINGS
I have two questions? any help would be nice. thanks.
well my first question is. i got a set of 315/75/16 on factory rims with a 3" bodylift and when i turn left the tire rubs but the right side doesn't? why?
and i keep reading about this pcm flash. what does that do and where can i get that done at?
thanks lots
thanks lots
When I go full right it rubs, but full left does not. I recently found out I needed a trackbar to recenter the axle and compensate for the lift. Do you have an offroad trackbar to compensate for your lift and the bigger tires you have? It might not be it, but theres a chance like it was mine. Arent 315's 35" tires too?
There is a bolt on each nuckle that is there to limit the steering. Apparently one is threaded in more then the other letting it travel further. Adjust that bolt and your good to go.
