Charging system voltage too high
Old Nov 13, 2007 | 09:07 AM
Rammer1500's Avatar
Rammer1500
Default Charging system voltage too high
I have code P1594 which refers to the charging system. When I check the battery voltage it shows 12.5 volts. With the engine running, the voltage at the battery shows 13.5 volts. This is not too high. What else could cause this code?
Any solution ??
Old Nov 13, 2007 | 09:40 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Charging system voltage too high
It's your alternator. It's getting ready to go out on you.
Old Nov 13, 2007 | 01:35 PM
greenmachine's Avatar
greenmachine
Voltage regulator in the alternator. You can change that yourself if you feel like it. Take the alternator to a shop they can fix it cheaper than buying one from auto parts store.
Old Nov 13, 2007 | 01:42 PM
rabbler's Avatar
rabbler
Check the voltage at the big stud off the back of the alternator. See if it matches the voltage at the battery. It's probable your alt is failing but dirty battery cables and corroded wiring between the battery and alternator can cause this symptom too.
Old Nov 13, 2007 | 10:09 PM
Socha_62's Avatar
Socha_62
Reset the PCM my unhooking the battert for a few minutes, if it comes back on you have a problem for sure.
In the winter and when its cold my Volt meter reads about 14.5v, and my multimeter agrees with it, I havn't throw a code ever.
Old Nov 14, 2007 | 05:31 AM
HankL's Avatar
HankL
With the Magnum engines Dodge put the voltage regulator inside the PCM computer...which makes it an expensive repair....and there is also a battery temperature sensor underneath the battery tray whose signal is used by the PCM to dial back the voltage in hot weather and ramp it up in cold weather. An out of whack battery temp sensor could cause the voltage to be unacceptable to the PCM computer.
