Flywheel, Flywheel, Flywheel . . . Help! If you can.
Old Nov 14, 2007 | 11:05 AM
br3ktw's Avatar
br3ktw
Default RE: Flywheel, Flywheel, Flywheel . . . Help! If you can.
Is there a way to manually turn the flywheel past the missing teeth in order to get the starter to engage so I can drive it to a shop???
Old Nov 14, 2007 | 12:28 PM
ICEMAN_CH's Avatar
ICEMAN_CH
I wonder if you could try and push it while in a gear? I don't know that's my best thought
FRUITPORTCAT's Avatar
FRUITPORTCAT
Yes easy way is to put the truck in OD and bump it with the key OFF. Or you could put a socket on the balancer bolt and turn it WITH THE KEY OFF.
Old Nov 14, 2007 | 01:21 PM
bill022572's Avatar
bill022572
Unless I'm mistaken - a 46rh is an automatic trans and what you need replaced is the flexplate. On my All-Data the labor is listed for 4.5 hours (with extra time of 0.7 for skid plate and 0.5 for dual exhaust - if applicable). The flex plate is listed for $38.60 (OEM part # is 53008669). Figuring about $50 to install flex plate to flywheel - just needs heated and put on) this would leave (at the highest total labor of 5.7 hours) about $750 in labor which figures out to $133 per hour flat rate. Man - I need to work at that shop.
Old Nov 14, 2007 | 05:23 PM
FRUITPORTCAT
Did not catch that that was an auto-thought it was stated as a stick. If its an auto you need a new convertor-flexplate does not have starter ring gear teeth, there are on the conv.
Old Nov 14, 2007 | 05:32 PM
br3ktw's Avatar
br3ktw
The dealer wanted like $482.00 for a new flywheel so I am guessing that was included in their $1200.00 estimate. Not sure though, but it seems thats the case. Still, even $750.00 is outta my range-yes its crazy!!! I have the ring gear purchased and someone willing to put on the existing flyweel for $40.00. Now I just have to find some good instructions for sliding the tranny back to get to the dang thing.
