98.5 Cummins Alternator problem
Old Nov 15, 2007 | 10:23 AM
coalburner24's Avatar
coalburner24
Default 98.5 Cummins Alternator problem
Hey guys I have a 98.5 Ram 3500 w/24v Cummins i've replaced the batteries and had the alternator checked i work at an Oreilly's so I did it my self and she checks out great. What's not so great tho is the fact that my battery isnt charging. I pust a Volt meter on the cables and show like 11.6 or so volts yet when i pulled it off the truck it tested just fine. Any ideas on what might be the problem here? Anyone had any problem like this before. Thanks for any help ya'll might be able to offer. Im beating my brains up on this one.
~Phil
Old Nov 15, 2007 | 07:46 PM
Parts/Service's Avatar
Parts/Service
Default RE: 98.5 Cummins Alternator problem
Follow the red battery cable to the power distribution center under the hood. Open the PDC cover. Look for a red 140 amp fuse atached to the end of that red cable. The fuse is bolted to the PDC. If that fuse is blown, replace it. Hope this helps......
Old Nov 15, 2007 | 08:23 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
The alternator is only part of the charging system. If the alt is good, you either have a blown fuse, open circuit or a faulty PCM.
