Troubles running barely idling
Old Nov 18, 2007 | 02:49 PM
my1500.net's Avatar
my1500.net
Default Troubles running barely idling
Ok guys I need some help. I was taking my daughter to school Thursday morning as usaul, went about 1 mile & it started to run rough, came to a stop sign & it almost died. So I turned around & headed for home to avoid a tow bill, it had very little power on the way home & up a hill.
Sitting in front of my house now it will idle but seems to have alot of unburned fuel out of the pipe & seems to be running on 4 cylinders.
Here is what I have done/checked:
Fuel pressure is at 50 psi
I lined up the timing marks to TDC at the balancer & the dist rotor seems to line up with the mark in the dist, as far as I can see with a mirror & flashlight.
I replaced the TPS just because it comes up so much here on the forum & I have not replaced it yet.
A couple months ago I did the Hughes plenum plate & at that time I replaced the plugs, wires, dist cap & rotor as well as the o2 sensors.
I am 38 & started wreching on Dodges when I was 16 but this is my first one with EFI so I need some of your combined wisdom to help me with my problem. I used to be "73scoutII" on here but changed when I got the .net address for fun.
My first thought was timing chain because I am at 153k miles but when I have lost timing chains in the past on 318/360 engines they just died but I considered that it could have slipped a tooth & I do not know if the newer ones use the same dumb nylon coated cam sprocket as they used to use.
Anyway the truck is a 1998 4x4 1500 5.9 automatic & any help you fine people could provide would be much appreciated.
My next step will be a compression test.
Old Nov 18, 2007 | 02:53 PM
my1500.net's Avatar
my1500.net
Default RE: Troubles running barely idling
Oh yeah I did get some codes for multiple cylinders missing after the drive home but not since eventhough it is still running the same.
Old Nov 18, 2007 | 03:06 PM
dhvaughan's Avatar
dhvaughan
have you got the digital odometer that will show codes using the on-off-on-off-on key seq ?
might want to pull the plugs and look at them to see if you can pin down a cylinder.
my first guesses -
overly rich mix = leaking/stuck injector. bad pre-cat 02 causing richness.
not firing = plug wires off, cracked cap, rotor, water/moisture, coil, plugs, wire cross fire/short
other = water in gas
idle only problem = iac
other sensors = tps, crank pos, cam pos, map, intake air temp.
won't rev up - cat.
Old Nov 18, 2007 | 03:29 PM
my1500.net's Avatar
my1500.net
I have a cheap code checker & I also have the Hypertech programmer which I believe pulls codes as well.
Cap, rotor, wires & O2 sensors have about 3000 miles on them & I ran it last night in the dark moving the wires around checking for spark leak but saw nothing.
I am going to pull the plugs & do a compression test on all cylinders, hopefully I will find which cylinders are wet & will swap those injectors to other cylinders. Or is there a better way to check injectors for leaking?
Old Nov 18, 2007 | 04:02 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Nope. AndDodge wasn't the only one to use them, and all manufacturers figured out they're a bad idea.
You're going to have to do some more testing and give us more info before ai can offer any good suggestions. The compression test is definitely a good place to start. I always like to eliminate mechanical problems first when dealing with mystery misfires.
Old Nov 20, 2007 | 06:32 PM
my1500.net's Avatar
my1500.net
Well I found the problem :-(
Along with a bent push rod & a bent valve. I guess at 150k miles it would be best to just get a crate motor than to do the top end. This is not what I wanted to find!
Old Nov 22, 2007 | 03:17 PM
my1500.net's Avatar
my1500.net
Well it goes under the wrench on Tuesday, I don't have a hoist anymore or the time so a shop near me is going to do the motor & take it my old machine shop.
Does anyone have a spec list on what I can get away with as far as internalupgrades that I can do without pissing off the computer, like a cam # or slightly taller pistons? The truck ran nice before this but a little more power would be nice & it still needs to pass Calif emissions.
I am running 285 tires & have factory 3.92 gears so it is not bad but I live in the mountains so if it not coasting down hill it is climbing them.
Old Dec 18, 2007 | 03:44 PM
my1500.net's Avatar
my1500.net
Well I got my truck back today & all is well $4186 was the final bill which included some extra stuff so I am back in my ram!!!!!!
