Water in floor
Old Nov 18, 2007 | 06:16 PM
NiotaRam1500's Avatar
NiotaRam1500
Default Water in floor
I have a problem with water in the passenger side front floor. The firewall is dry so I suppose that it isn't running down it. Any ideas?
Old Nov 18, 2007 | 09:08 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: Water in floor
There is an A/C evaporator drain tube that runs down the firewall on the passenger side. It sometimes gets clogged with a moldy "goop" and thenleaksonto the passenger floor board. Push something like an unfolded paperclip or pipe cleanerup inthere to unclog it.
Old Nov 18, 2007 | 09:36 PM
mikesjunk's Avatar
mikesjunk
Check the 3rd brake light on the back of the cab. Seems the gasket leaks thenthe water ends up in the passenger floor. Mine had this issue and sure enough a little silicone fixed it up....no more wet floor.
Old Nov 19, 2007 | 12:05 PM
NiotaRam1500
ORIGINAL: aim4squirrels
I can't find the drain tube. Is it inside the cab or under the hood? Can it be seen without removing some part of the dash? Thannks for the help.
