More Problems
Well its a never ending story for me.
The problom, at mainly 40m/h + when i let totaly off the gas i get this virbrating almost like a shaking but not, then when i get back on the gas, it feels as almost as if its slaming in to gear as if u where sliding something in to place then it catches. Now i did just have my tires roated and rebalanced but they 4 got a nut and i dont think they did a good job with the balancing so i will have them redo it, but i dont think that is it. Now i had a bran new transmation put in about 15K miles ago. Its still under warnty so i it will be coverd, now do u think it is transmation probloms? *now it was also slipping a little bit at high speeds, liek goin 60 and hittin it to pass someone* The Tires? or maybe something like engine mounts?
Problom #2, i had to replace my back 2 stock, now i had to put out my stock spire tire that has been under the truck since 97 and had no way to get it out. Now after replaced the shows and stuff i'm getting a clicking noice in the back. My first quess was u-join in the back, well they all check out in the drive train. *This is also after i just has the tires redone as stated about i will have them redone it could make this go away* now this only happens when i'm picking up speed aobut 1-20 m/h then stops. My 2nd guess is one of my pipes moves back and forth abut 1/2 a inch but has a bushing still and makes no clicking noise when io shake it my self. but maybe its hitting something?
I know its almost impossable to figure what it is with these to over the interent poor describtions but any ideas will help. Mains the first one is what i'm most worried about.
UPDATE!!!!
Well dont know about you, but i love it when people update and explain what there problems where. Well guess what it was a bad ujoin connecting the back drive shaft. To bad i didnt find that out before it was shreaded to peaces in the middle of the intersection. My truck is in the shop and i get to walk to school and work tomarrow =(
