Rear Diff Fluid Change
Old Nov 25, 2007 | 06:15 PM
padodgeram's Avatar
padodgeram
Default RE: Rear Diff Fluid Change
ORIGINAL: Kev_n_AZ
FYI: Dodge does NOT use any paper gaskets when doin diffs. they only use RTV silicone based fast set.
Dodge may not sell it to ya. call first.
otherwise look at napa or autozone for silicone based quick dry rtv. my stuff was orange.
Thank you !!!!! DO NOT USE A GASKET !!! ..use rtv or napa has whats called the right stuff .. take that gasket back unless you wants leaks and it will happen..
Old Nov 25, 2007 | 06:26 PM
Cereal Killer's Avatar
Cereal Killer
yeah, I would never have considered just putting the paper gasketin there with no RVT sealant. That would be retarded.
Old Nov 25, 2007 | 06:42 PM
ryans590's Avatar
ryans590
to tell your gear ratio when you have the cover off count the #of teeth on the ring and divide it by the # of teeth on the pinion (eg 41 teeth on the ring 10 teeth on the pinion, 41/10=4.1 or 4.10 gears)
to tell if its limited slip when you have the cover off just look for the cluch disc packs
Old Nov 25, 2007 | 07:09 PM
dhvaughan's Avatar
dhvaughan
i wouldn't put any rtv on the rubber gasket.
wedges ? i don't know. a stiff putty knife is best, as it cuts the seal without bending the cover.
MMO. no. if you have lsd then you need a small bottle of friction modifier. if you have open, then just put in your 90w oil and nothing else.
paper sticker on drivers side rear axle tube will identify open vs limited slip.
note pictures below. the carrier of the lsd has more stuff in it, incl clutches and clips.
picture of open diff.
picture of limited slip.
[IMG]local://upfiles/38819/14AD03D5F96E468582B4DEB0981794D1.jpg[/IMG]
[IMG]local://upfiles/38819/41618F603502409E9AAE6DD254183028.jpg[/IMG]
Old Nov 26, 2008 | 05:22 PM
thunderz's Avatar
thunderz
AutoZone carries "the right stuff" as well. I just picked some up to do the diff fluid change.
Old Nov 26, 2008 | 06:18 PM
aim4squirrels's Avatar
aim4squirrels
hopefully he figured it out last year.
Old Nov 26, 2008 | 07:04 PM
zman17's Avatar
zman17
Retired Moderator - RIP
And it sucks that people can't give the results!
Old Jan 24, 2009 | 09:52 AM
iwhitne's Avatar
iwhitne
Yeah I know this thread is really old.. but I will be doing a diff fluid change this spring.. along with the transfer case.. not too sure about the tranny yet
Old May 17, 2009 | 09:32 PM
iwhitne's Avatar
iwhitne
well.. I'm following up... I did my front and rear diffs today. Changed out the oil with some Lucas 80w-90. Added a bottle of friction modifier to the rear as well. Used the black RTV and everything went smooth... and it's difficult not to get the rap on yourself.. so now I smell like a rear end! hahah
Old May 17, 2009 | 09:52 PM
vmann's Avatar
vmann
At the dealership i work at we don't use gaskets for that stuff. We use Grey silicone all the way around and stick it right on, tighten it, then fill it up.
