water pump
Old Nov 25, 2007 | 12:55 PM
turtlegirl's Avatar
turtlegirl
Default water pump
hey there, can anyone help this dodge girl with instructions on how to replace my water pump? came home last night and had radiator fluid coming out the seal from the pump area. all the hoses are good, just that dang seal..............thanks in advance
Old Nov 25, 2007 | 12:59 PM
XXL 1500's Avatar
XXL 1500
Default RE: water pump
Welcome to Dodge Forum!
Check out the DIY section at the top of the main 2nd gen Home Page
Old Nov 25, 2007 | 01:00 PM
XXL 1500's Avatar
XXL 1500
https://dodgeforum.com/m_224411/tm.htm
Good Luck!
Old Nov 28, 2007 | 01:30 PM
guerillawarfare's Avatar
guerillawarfare
It's time consuming, but not a hard job. You just need to start taking off parts starting at the plastic fan cover, and keep going back until you get to the water pump. Take the hoses off the pump pull the pump and install the new one. Then put it all back together. The only problem I ran into, was the O-ring that comes with the new pump kept splitting. I went back to the store where I bought it twice, but once I split the third one, I went to a parts store and bought a blue/green AC O-ring that was the same size and then rubbed off the color. Once the color was gone it was just barely smaller than the original and slid into place, and has not leaked for over a year now. Good luck
