tires and axles
Old Nov 27, 2007 | 02:30 AM
  #21
shott8283's Avatar
shott8283
Default RE: tires and axles
you also gotta remember jason alot of them D44's that hold up to that abuse your mentionings are also the HD44's... lovley jeep axles...
i have witnessed many of our D44's break during "easy" trailing,,, but like you said.. its whats under the tires that really counts..
Old Nov 27, 2007 | 12:56 PM
  #22
Socha_62's Avatar
Socha_62
Very true, sometime shafts do just suck and are old or get a hairline crack over the course of their life, I watched a kid I live with break a shaft just getting hit rig on the trailer! But like I said, it was already weak and needed just a little more to break so it did.
To me it seems that on a DD/occasional trail rig if your beating it hard enough to break a shaft other things will go first, like body panels
Also the HD44s just have a larger bearing in the hub and are usually 8 lug, other then that they're the exact same everything.
