little adivce for 2" lift
so my 2" spacer/block lift and my 3" body lift came in. i plan on putting the 2"'s of lift on myself and getting the body lift proffesionally done. but i read all i could find about blocks and spacers. even the DIY's. but the DIY for the spacers was more of a spring install. it was still some good information and im ganna follow what he said to do but i was wondering if theres any tips that might help me out to get it done easier. or anything to watch out for. also i could find barely any information orDIY for blocks. so are they hard to install? any input helps.. thanks
well ive researched the blocks and never read of anyone having a problem. but i might not even put them in becuase the spacer lift up front might look good enough without lift in the back. after all, it is a leveling/lift kit.
http://www.pavementsucks.com/tech/bodylift.php
There should be instructions with the spacers.
Take shocks loose, disconnect sway bar links, drop axle till they fit, bolt in place, reverse the previous. Get an alignment.
yea coil spacers arent to hard to put on i just reccomend using a good coil compressor and it will mak your day much easier.... but the install aint bad....
