Check engine light
This may sound stupid but my check engine light comes on and off a few times during the day, are there certain things that may cause that?Everything seems fine nothngs loose no wierd noises and i got all my fluids.Should i jusget my buddy to run diagnostics and get the codes?
ya you should get the codes checked you could have a sensor wire loose or have a miss that comes and goes my truck does that if i start it alot during the day i will see it come on and off 3 times or so just all depends on how she wants to run lol
mine comes on every so often. mine calls out a cyl. 5 missfire. i re-routed my spark plug wires, and made sure my pcm plug was nice and tight. it goes away, but comes back every 2 months or so.
A blinking CEL means a misfire. Be prepared to have to replace your catalytic converter if it turns out to be #6 and/or #8 that are misfiring and nothing cures the problem. A local muffler shop can pressure test the car for you.
