Wet floor boards
Old Nov 28, 2007 | 10:50 PM
Carpenter74's Avatar
Carpenter74
Default Wet floor boards
Hello all new to forums.
97 Ram 1500 4x4 5.9 Ext cab.
I have been reading your posts and your information has been a real help. Especially with a water pump replacment last weekend.
Another problem i have is with water (rain - no coolant loss or smell/ texture) building up on my drivers floor board.
Can't locate the leak.
Any known trouble spots or issues?
Ideas what to check?
Sig and pic soon.
Old Dec 4, 2007 | 06:51 PM
ram pu 2's Avatar
ram pu 2
Default RE: Wet floor boards
hi had the same problem with my 97 ram 3500 v10, i got fed up with drivers footwell being full of water so i stripped out the complete interior of my truck cleaned and painted floor with hammerite smooth paint then soaked complete outside with water and discovered water was coming threw rear window it leaks down rear panel then runs along floor into front footwells i resealed rear window especially around top where plastic roof trims enter rear window seal glad to say now fixed and cab and footwells now dry, hope this helps tony(uk)
Old Dec 4, 2007 | 08:12 PM
White Ram's Avatar
White Ram
I had the same water problem. Got a new 3rd brake light gasket from the dealer ($9?), used some clear RTV, and presto, no more water. Amazing.
Do a search on this topic. It's been discussed many times. There are other areas to check also, I just don't remeber what they were.
