tire question
Old Nov 29, 2007 | 07:26 PM
reynoldsrobbie's Avatar
reynoldsrobbie
Default tire question
I have a 1995 Dodge Ram Sport with the 5.9L. I will be installing a 3" lift on it as soon as it comes in from Top Gun. What is the largest size tire that I can mount on the stock chrome wheels, with that lift?
Old Nov 29, 2007 | 08:35 PM
spaz_22's Avatar
spaz_22
Default RE: tire question
you will be able o fit 285/75r16 or 305/70r16's easily and look very good, but you may be able to fit some 315/70r16. but i would just go with the 33 inch tire, but if you don't mind it rubbing a little you can fit the 315's..
Old Nov 29, 2007 | 09:03 PM
reynoldsrobbie
ORIGINAL: spaz_22
So are the 285's and the 305's both considered a 33" tire overall? And both of those widths will fit the stock chrome wheels? How bad and when does the rubbing occur?
Old Nov 29, 2007 | 11:01 PM
ryans590's Avatar
ryans590
the first number isent the hight of the tire, its the width in millimeters, the next number is the hight as a presantage, so depending oin the precentage SOME 285 and 305 tires will be 33 in tall
to answer your question 33's will clear, 35's will rub slightley on full turn with factory wheels however i have 35's and a 3 in lift and the rubbing isent too bad as long as you know not to crank it
Old Nov 29, 2007 | 11:12 PM
reynoldsrobbie
so, I should be stylin if I throw on some 2" coil spacers then, for the front. Are you running 35" tires on stock wheels?
Old Nov 29, 2007 | 11:23 PM
ryans590's Avatar
ryans590
yah thats what i have, look here for some pics https://dodgeforum.com/m_1051854/mpage_1/key_/tm.htmthere about half way down
