96 5.9 , runs great but every so often while driving it will stumble, like you turned the key on and off, it will also die at van idle every so often , (aic) , did not think that would affect after idle though, thanks, new to the dodge scene, have changed both 02 sensors ,gas cap and installed a 180 deg stat.
Mine did this and I could get out and hit the bottom of the gas tank and it wld statrt right back up I changed the fuel pump and walla no more probolems
