I need a good set of...
Old Dec 10, 2007 | 03:45 AM
IndyRamMan's Avatar
IndyRamMan
Default RE: I need a good set of...
ORIGINAL: SilverRam_01
ORIGINAL: IndyRamMan
Does anyone know where I can find a good set of muffler bearings? Iv looked all arround and I can only find them for $129.99 a piece.
Are you sure it's the muffler bearings? I've heard that low catalytic converter fluid can cause the same symptoms... you might wanna check that out.
well what size catalytic converter filter do i need when i drain and replace the fluid?i bet it will regain about 11 kilopascals when i do that.
Old Dec 10, 2007 | 03:59 AM
SilverRam_01's Avatar
SilverRam_01
The 2.73X19.42" one, and make sure you get the one with the removable o-rings, so that you can get a better seal when you butt it up to the inverted injector pump. While you're down there, take a look, and see if your adjustable powerband is set-up so you can accomidate the extra 11 kilopascals...
BTW check out http://kalecoauto.com for them muffler bearings
Old Dec 10, 2007 | 04:29 AM
Wrestling4x4's Avatar
Wrestling4x4
haha ok i have been studying for finals all night. have a portfolio and 3 finals tomorrow so im not a happy person. but this put a big smile on my face. thanks for that one..
Old Dec 10, 2007 | 04:55 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: Wrestling4x4
yay, atleast im not the only one. Iv been up for almost 32 odd hours now, with another 12 before i can snoose. Im about to kill someone! Next time I stay up this long is probabily when I do everything to the spruce goose in january.
Old Dec 10, 2007 | 10:38 AM
WesV's Avatar
WesV
You know if your muffler bearing is out there is a good chance that your kuhnueter valve is plugged as well and not opening properly. Unfortunately they are not cheap either....
Old Dec 10, 2007 | 10:59 AM
Socha_62's Avatar
Socha_62
$49.99
http://www.kalecoauto.com/index.php?...products_id=10
[sm=bling.gif]
Old Dec 10, 2007 | 12:20 PM
1500sport's Avatar
1500sport
"Walk softly, but cary a big block"
Can anybody find out what is wrong in the previous line, I'll give ya a hint. Good sig. had to give ya some **** though.
"Walk softly, but carry a big block"
