DO I NEED A NEW CAT CONVERTER
Old Dec 11, 2007 | 06:04 AM
HankL's Avatar
HankL
Default RE: DO I NEED A NEW CAT CONVERTER
Check with the dealership to see if your truck is eligible for a free catalytic converter under the terms of the big recall for 1996-1999 Rams:
http://www.arb.ca.gov/newsrel/nr122105.htm
http://epa.gov/compliance/resources/...ler-fcsht.html
Old Dec 14, 2007 | 12:33 PM
mcss8541's Avatar
mcss8541
Thanks my friend but i just missed the cutoff by 600 miles. Mine has 120600 miles and the cut off is 120000.
Old Dec 14, 2007 | 12:42 PM
mcss8541's Avatar
mcss8541
Roger That Iceman. Just type in o2 sensor?
Old Dec 14, 2007 | 12:54 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Replace the cat or else be subjected to a blinking Engine Light, which means misfires. It usually cause #6 and #8 to misfire due to the converter being clogged and too much back pressure.
Old Dec 14, 2007 | 12:55 PM
mcss8541's Avatar
mcss8541
Hey I ce I did a search and there were alot of posts regarding o2 sensors but none came up with your name as the author. Can you help me narrow down the search? Thanks!
Old Dec 14, 2007 | 02:04 PM
ICEMAN_CH's Avatar
ICEMAN_CH
https://dodgeforum.com/m_966388/tm.htm
Here yea go. It took me a little bit to find it to. I ended up using google.
