35's with 4.56's
Old Dec 10, 2007 | 10:23 PM
asimpson97d's Avatar
asimpson97d
Default 35's with 4.56's
My dad's truck has 35 inch tires with 4.56 gears and needs a different speedo gear for his 1997 Ram. It has an automatic trans and a 231 transfer case. I know there is a site to tell you the teeth but I don't think i am doing it right nor does it give me any part numbers. Has anyone else got this combo and have an idea on the correct number of teeth or a better website to use? I don't want to recal. with a tru-speed or through the comp...to broke for that. any help would be greatly appreciated. thanks
Old Dec 10, 2007 | 10:33 PM
JCliffordd's Avatar
JCliffordd
Default RE: 35's with 4.56's
Website
http://www.rocky-road.com/calculator.html
Dont know if thats one you have or not you can try it just trying to help as much as i can
Good Luck Man
Old Dec 10, 2007 | 10:44 PM
spaz_22's Avatar
spaz_22
..maybe your truck doesn't have a gear and only has a sensor? I'm not sure what year dodge started doing this but if it only has a sensor and no gear then you will have to go through the computer
Old Dec 10, 2007 | 10:52 PM
05DodgeRamHemi's Avatar
05DodgeRamHemi
35" tires with 4.56 gearing.....MINT
Old Dec 11, 2007 | 12:05 AM
acemaverick274's Avatar
acemaverick274
35's with 4.56s is really nice. I have 37" tires on my dodge with a 4.10 rear end. I'm going lower such as 4.56 or maybe even 4.88but its not bad for what it is.
Old Dec 11, 2007 | 04:56 PM
asimpson97d
no it is a gear- my buddy has a jeep with the same set up- transfer case- axle gear ratio- trans- and is using a 37 tooth which seems to make it only 1-2 mph off. I ordered a 37 tooth for the truck. We shall see how it turns out! thanks for your help guys!
