Wheel Cylinder Swap on a 2001 1500 Updated, crap!
Old Dec 12, 2007 | 01:51 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: Wheel Cylinder Swap on a 2001 1500
There's plenty of room left in the master cylinder for this. The newer 2nd gens (99 up I believe) even had a larger MC put in because of the braking complaints if I remember correctly. If you really want them tight, upgraded to braided SS lines that won't flex when you push the pedal.
Squishybrakesor excessive pedal travel are most likely due to the auto adjusters not adjusting like they are supposed to, or it's possible that flooring the brake pedalona manual bleed pushes the MC seals too far off oftheirnormal plane of travel and the seals get fouled by loose debris. Or possibly a bad bleed job or leak in the system.
If your brakes are squishy, try driving in reverse and build up just a little steam and give the brakes a quick jab or 2 and see if that doesn't tighten them up. That the way the auto adjusters on the drum shoes are supposed to self adjust.Alternatively, you can put the rear axle on stands andadjust the star adjuster with astandard screwdriver until the shoes just rub, just spin the wheel and adjust until you barely hear the shoes rub the drum.
Old Dec 12, 2007 | 03:29 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: aim4squirrels
My dad was an automotive engineer. I know all about the reversing to get the adjusters out (first thing I did) as well as adjusting the star until there is a slight amount of rub. Problem is, my backing plates didn't have the hole punched. Another one of those projects in the future.
Old Dec 12, 2007 | 05:21 PM
aim4squirrels
Hey VW,
What's the deal with HankL and the naughtybit? I laugh everytime I read that.
Old Dec 12, 2007 | 08:59 PM
White Ram's Avatar
White Ram
"If your brakes are squishy, try driving in reverse and build up just a little steam and give the brakes a quick jab or 2 and see if that doesn't tighten them up. That the way the auto adjusters on the drum shoes are supposed to self adjust."
I coulda sworn that reardrum brakesare adjusted by using the parking/emergency brake.
Old Dec 12, 2007 | 09:40 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: White Ram
Stop swearing.
Anyway, the parking brake will help, but the best remedy is to go in reverese and hit the brakes. It forces the adjusters into action. And, in the old Air-Cooled Volkswagen world, everyone knows that the old VW's have 4-wheel drum and are well versed in adjusting them to barely rub.
Old Dec 12, 2007 | 10:06 PM
v10power's Avatar
v10power
I did put the chevy dually cylinders on my dually. I noticed a slight differnce. but mine is a 95.
Old Dec 12, 2007 | 10:10 PM
aim4squirrels
Picked up the wheel cylinders tonight, beefy! Got some new shoes too.
If the weather breaks here soon, I'll get them on by the end of the weekend.
Old Dec 13, 2007 | 07:03 AM
HankL's Avatar
HankL
from a practical standpoint
replacing the stock 'starwheel' thread rod
with an aftermarket one that has a different
number of acme threads per inch
is a worthwhile thing to do to get the automatic adjuster
to worth slightly better
Old Dec 13, 2007 | 08:41 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: HankL
Suggestions?
Old Dec 14, 2007 | 09:56 AM
aim4squirrels
Well crap,
The cylinders are a 1/4" too short for the 2001. At least that's what the mechanic who's fixing my truck right now said.
Replaced the brake shoes on my truck at the same time. That was a PITA. Used the Passenger side as a template. Took it out for spin, and the shorter cylinderlet the star wheel adjuster move too much, it came loose and it fell off, bounced around the drum, scoring the heck out of it. They're replacing that right now as well as the wheel cylinder.And shoes on the passenger side; those shoes were smooth as glass.
$485 later and I'll be back on the road. Oh well, Merry Christmas to City Garage! Guess I learned my lesson for trying to make a ill fitting part work. Least everybody else knows better now.
