T-Stat
Old Dec 11, 2007 | 09:34 PM
  #21
greenmachine's Avatar
greenmachine
Default RE: T-Stat
ORIGINAL: greenmachine
Silver-- I understand the open/closed loop. Like the mass air sensor that requires air temp for fuel mixtures, how does the ecu/m use the engine temp as a perameter.Why throw a CEL for cold temp? The thing will work unless the block is froze, right? I am just trying to get a better understanding of how this is all tied together. Depending on how it works you can consider this a performance mod?!
The PCM uses coolant temp because it is not a mass air engine (i.e. no mass air sensor), it is a speed density system. In fact, it uses a combination of sensor inputs to determine things like fuel curves and open/closed loop modes among other things. I don't think you will actually get a CEL from too cold of a t-stat, but many people get a stored code.
I do not consider the t-stat change a performance mod. It might help other performance mods you have by reducing the likelyhood of pinging caused by those mods (like advance timing you might have from a PCM performance mod for example). But by itself, it is not a performance mod.
[/quote]
I was just using the mass air flow sensor as an example. Thanks for the lesson. When it comes to all the electronic bs I have a lot to learn. These trucksbeing my first and only attempt at modifying a computerized vehicle. Pretty much old school-- carb, distributor, and well made internals.
Old Dec 12, 2007 | 12:34 AM
  #22
Damian's Avatar
Damian
Default RE: T-Stat
FWIW I run a 160 stat here in Georgia and have no problems in the winter. It's especially needed for the summer as it gets 100+ on a regular basis here.
With the stock stat in the summer my truck would reach well over 210 degrees and knock like crazy unless I had 93 octane in the truck. With the 160 stat the truck stays cool in the summer, no knocking with 89 octane and never reaches about 200 degrees.
Also, I have a hypertech power module FWIW
Old Dec 12, 2007 | 07:40 AM
  #23
steve05ram360's Avatar
steve05ram360
Default RE: T-Stat
I've run a 160 t-stat before and it took forever to warm up and it ended up tossing a code. I recall that the pcm goes into closed loop somewhere around that temp and I wouldnt recommend a 160 in a daily driver. If its a tow vehicle, maybe. you will get your best performance with a 180* IMO
Old Dec 12, 2007 | 11:42 PM
  #24
IndyRamMan's Avatar
IndyRamMan
Default RE: T-Stat
[/quote]
I cant chime in on exactly how the pcm is effected by a lower t stat, because I havent seen the fuel maps and the variables that cause the patterns, but I can speek from first hand experience. The 160 has not given me any problems, no cel and no stored codes. IMO theres really nothing to consider other than overheating/underheating. If you are overheating, lower it (try to nail down why its overheating). If your underheating, raise it. If its fine, leave it alone. Just my .02 on that.
Old Dec 13, 2007 | 12:56 AM
  #25
echseman's Avatar
echseman
Default RE: T-Stat
damn. i should go to electric fans. haha. it looks like the extra room would be nice for when you need to do some serious work inside the engine compartment.
