Blah! Truck issues.
Old Dec 18, 2007 | 12:08 AM
kowboydmac's Avatar
kowboydmac
Default RE: Blah! Truck issues.
Do I have to take the whole arm off to install them?
Old Dec 18, 2007 | 01:06 AM
SilverRam_01's Avatar
SilverRam_01
My trucks 2wd too, and I need to do bushings in my front end, and the ones on the control arms, I haven't done it, but it looks like you have to pull the shafts to get the other bushing in there... IDK it's too wet and I'm too poor to be doing anything now.. I need ball joints too
Old Dec 18, 2007 | 07:25 AM
dhvaughan's Avatar
dhvaughan
no personal experience on dodge, but i think you have to tear it all the way down to a pile of parts on the floor (including the coil spring), and then put it all back together.
Old Dec 18, 2007 | 08:32 AM
tothewall's Avatar
tothewall
Thanks to that, two girls think I have a very crappy truck! lol.
Sorry dude... It sounds like you DO have a crappy truck.
Good luck getting it all fixed... At least you had the two chicks IN your truck. Some guys dont even get that far.
Old Dec 18, 2007 | 09:18 PM
kowboydmac's Avatar
kowboydmac
My truck is weird, it'll run great and then spazz out, then run great again. I think i gotta flash the ecm or whatever. and then the water pump and some other stuff.
Old Dec 19, 2007 | 12:53 AM
kowboydmac's Avatar
kowboydmac
Well I cleaned out the Throttle body and the IAC. I don't have a pic of the IAC but here's a pic of the throttle;
Also used the CRC Electric cleaner to clean out all the connections; started right up and idled a bit nicer after the first shot. Fixed the CD player too. go figure? lol.
Old Dec 20, 2007 | 09:44 AM
kowboydmac's Avatar
kowboydmac
Well through searching, it seems that night was the truck saying, "hey i need a new water pump and heater core". I just can't figure out if those two really affect the idle/overall driving of the truck. I know it would help keep it cooler, so is it more of a domino effect? Also, I'll be replacing my exhaust system in the next month or so, minus the headers. So new muffler, o2 sensors, pipe and gutted cat, which I presume would help idle as from what I can tell, my cat is a little stuffed.
I'm going to hold off on the suspension stuff, but in the next few weeks (After christmas rush) i'll order tie rod's and the arms, pitman and idler. After those are installed I'll see how the suspension is holding up. I still think new shocks would help my situation though.
