leanin to the right
Old Dec 18, 2007 | 04:01 PM
Ramafication's Avatar
Ramafication
Default leanin to the right
hey guys, ive had the truck on the road for a little over a week, seems to run fine since the motor swap, but im noticing a more gradual lean in the front en on the driver side, the passenger side shock has a gap and bounces around losely but thats not the weak side of the truck which boggles my mind, but it does rattle because its not in there tight. would it be a bad driver side coil? or possibly could it be my rear leaf affecting the front end.how can you test this? thanks in advance
Old Dec 18, 2007 | 04:11 PM
CSCustomCars's Avatar
CSCustomCars
Default RE: leanin to the right
I have hte same problem with the Driver's side lean in the front. I'm thinking it's either the spring, or some kind of worn out bushing.
Old Dec 19, 2007 | 11:32 AM
addy4368's Avatar
addy4368
i also have the same problem, i replaced the front shocks and its still leaning i'm also its a worn spring or bushing.
