Oh crap does anyone know how to put an engine toghether?
Old Dec 24, 2007 | 07:57 PM
dhvaughan's Avatar
dhvaughan
Default RE: Oh crap does anyone know how to put an engine toghether?
just top off the radiator and overflow tank (to the max line) once per day when its cold. it should purge the air and suck in coolant from overflow and stabiize with in a few days.
Old Dec 27, 2007 | 08:14 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Here's a trick I use to eliminate air pockets when I re-fill the antifreeze.
Manually push open your thermostat when you have it out of the engine and slide two aspirin (yes plain aspirin) into the thermostat to hold it partially open. Then complete the installation of the thermostat. Fill your radiator completely with your desired antifreeze/water mix.
The aspirin hold the thermostat open long enough to allow all of the air bubbles to leave the engine and then they completely dissolve. By using this method I have never had an air pocket issue.
Hope it helps.
Old Dec 27, 2007 | 08:24 AM
dhvaughan's Avatar
dhvaughan
good tip.
eliminates that headache.
Old Dec 27, 2007 | 08:56 AM
DPR250R's Avatar
DPR250R
When putting the intake manifold on make sure you drop it straight down and do not move it around after it is in place.
The front and rear gaskets can get pushed out of place. (Ask me how I know)
I found my rear gasket pushed out right after I finished torqing the manifold. I had to take it back off and decided to use silicone instead of the rubber gaskets.
Since the manifold is somewhat heavy and you cant stand directly over the engine and drop it on... you might need an extra set of hands to help guide it into place.
Another site recommended grinding the heads off of the old manifold bolts and use them as dowels.
Old Dec 27, 2007 | 10:12 AM
turkeyhunter1962
ORIGINAL: DPR250R
For our Magnum engines this works great as it is a straight down mount.
