KEYLESS ENTRY
Old Dec 23, 2007 | 12:30 PM
engineblock's Avatar
engineblock
Default KEYLESS ENTRY
hello everyone i have an issue, when i bought the truck the previous owner had installed an alarm to a no power door truck (no power windows, no power locks etc) when he installed the alarm he had put a keyless entry which they had installed themselves but i was moving the wires around because i door wouldnt unlock i had accidently miss wired the rlay in which they had installed to it. I have searched the internet for weeks now but no luck. I also contact the owner but he said he had lost the diagram to it, so i am here now asking you guys if any of you have done this kind of procedure.
My alarm is a Hornet 740t alarm system.
Old Dec 23, 2007 | 12:58 PM
jinxedwarrior's Avatar
jinxedwarrior
Default RE: KEYLESS ENTRY
You can get the install manual here, but you have to register with the site to get it.
http://www.the12volt.com/installbay/...m=+Hornet+740t[align=left] [/align]
Old Dec 23, 2007 | 01:39 PM
engineblock
hey man i cant figure it out, i have registered already but can not figure it out
Old Dec 23, 2007 | 02:17 PM
jinxedwarrior
Looking at the diagrams in the install manual, all the relays they mention are optional. You're either going to have to look at each relay diagram and match the wire colors to what you have in your truck and wire them according to the picture, or trace each wire in your truck down with the diagram on page 29, and wire it up yourself.
Old Dec 23, 2007 | 02:19 PM
engineblock
do you have the direct link to that if you dont mind helping me out
Old Dec 23, 2007 | 03:03 PM
jinxedwarrior
you need to open a separate tab or window and sign into the12volt.com, then come back to this tab/window and click on the link above. once that opens you click on the hornet 740t.pdf link to open the manual in adobe. then you can print the entire diagram out if you need it.
