code P1281
Old Dec 24, 2007 | 02:20 PM
veilside3kgt's Avatar
veilside3kgt
Default code P1281
ofcourse I have another question...I have a check engine light that I have read off my OBDII that comes up with code P1281 which I believe is something like "engine taking to long to get up to temp" I just changed my thermostat since it was broken and stayed open...but I tried to clear the code but it will not clear the dash??? anyone have an idea how to fix? Thanks!
Old Dec 24, 2007 | 04:30 PM
WayneC's Avatar
WayneC
Default RE: code P1281
Your code reader should have a feature to reset the PCM. Or just wait, the code will clear itself after a couple of drive cycles when the computer sees everything is kosher again.
Old Dec 24, 2007 | 04:36 PM
TheForce55555's Avatar
TheForce55555
Unhook the terminals on the battery and turn the Key switch to start for about 15 seconds and that should reset it
Old Dec 24, 2007 | 05:56 PM
veilside3kgt
i hit the erase button on my OBD II but it did not reset on the dash but I will drive a few times and see if it goes out...thank you for your help guys.
