Fog light help
Old Dec 28, 2007 | 05:26 PM
Mudbone25's Avatar
Mudbone25
Default Fog light help
Fog lights on my 94 ram 1500 havent worked since i got my truck. So now that i have some money im trying to fix them. I replaced the bulbs today but still no lights. I opened up the fuse box under the hood and there wasnt a fuse in the slot thats labled for the fog lights. i checkd my owners manual and they dont even list fog lights anywhere. Is there a fuse inline that im missing and if so where would it be?
Old Dec 28, 2007 | 10:11 PM
jnellydodge's Avatar
jnellydodge
Default RE: Fog light help
I know what you are talking about i had the same issue, yes there is a fuse for the fog lights that is in its own little compartment on the side of the fuse box. Not in the fuse box. It's Hard to explain, let's say you are standing on the drivers side of your trucklooking at the fuse box. On the sideof thefuse box opposite you there are a bunch of wires and a few rubber/plasticfuse housings that some of the wires go into.Take them apart and see ifone of the fuses inside are blown....sorry if iconfused you more, ive had this same issue,fog lights dont work,checked bulbs, nothing, looked forfuse in the fuse box, nothing, finally started digginginto it and found that the fuse isnt even in the fuse box.Good luck.
Old Dec 29, 2007 | 04:23 PM
Mudbone25's Avatar
Mudbone25
I think i know what your talking about.. i remember seeing a black box with wires heading to it right nexto the fuse box. ill take a look a little later. Is this how the stock foglights are wired or would you think somone put them in them selves.
Old Dec 30, 2007 | 03:38 AM
Mudbone25's Avatar
Mudbone25
So i went and took a look for that fuse. I found a 20 amp fuse in a black box to the right of the fuse box. changed it out still no lights. so then i pulled the switch out of the dash and messed around with that.. it was getting dark so i couldnt see that well. but from the looks of it the contacts were corroded. I got the lights to work after that. Would i have to go to dodge directly to replace the switch?
