intake & exhaust
Old Dec 29, 2007 | 05:25 AM
xdfrance's Avatar
xdfrance
Default intake & exhaust
I'd like to (have to) change intake system and exhaust line
wich could you recommend me ??
KN system ?
and exhaust line ???
online shop to buy, shipping to europe ??
Thanks
Old Dec 29, 2007 | 12:05 PM
motorbrreath's Avatar
motorbrreath
Default RE: intake & exhaust
k&n cold air intake or round air cleaner with the k&n filter in it. exause i would use a single in dual out flowmaster 40, with 4' pipes out the back at an angle. i dunno what the french laws are though so research that before makin it loud.
Old Dec 30, 2007 | 03:27 AM
xdfrance's Avatar
xdfrance
Ok Thanks, i will check about the catalyst problem
Old Dec 30, 2007 | 08:42 AM
HankL's Avatar
HankL
spend money on the exhaust first
and get the sound you like
plus try to get the backpressure at full throttle and 4000 rpm
below 2 psi, where hp gain should be 12-14
over the stock system with a backpressure of about 7 psi.
Avoid a tailpipe length in the 55 to 75 inch range
because it can cause a drone noise at highway speed rpm range.
