Removable trays in single cab
Old Dec 31, 2007 | 06:22 PM
95 Jamin Ram's Avatar
95 Jamin Ram
Default Removable trays in single cab
I have a 1995 ram 1500 single cab. i just put a 12" kicker L7 in the back behind the seats im trying to get a little bit more room for the seat to go back but those black litle things that hold up those trays or the net are keeping it from going all the way back. i tried pulling up on them but they dont really move at all. are they even removeable ? and if they are how do you take them out? Thanks
Old Dec 31, 2007 | 06:56 PM
gsarmed's Avatar
gsarmed
Default RE: Removable trays in single cab
They are removable. Take a hammer and hit them from the bottom to the top. They will come out. They're clipped in tight. Smack them hard with the hammer.
Old Jan 1, 2008 | 02:09 AM
95 Jamin Ram
thanks ill try it tommarow with a rubber mallet
Old Jan 1, 2008 | 01:45 PM
bigmanram's Avatar
bigmanram
jamin ram...
are wanting to know about the trays themselves or the clips that they snap into on the back wall. they tray is what u'll need the hammer for. the clips on the back wall will not com out witha hammer. to get them out u gotta remove that back pannel. ( take the screws out of the black tub on the bottom, remove it and roll back the carpet. take out all the screws holding bottom edge down......... pull the clips holdin up the side panels over the rear speakers and take out the screws holding edges of the back panel. and pull on the panel easy there are a few clips on the top edge (bottom of therear window)). becarefull removing the panel it will be a tight fit on the sides. once the panel is removed 2 or 3 screws holds each clip. its real easy to do and it will helps give u more seat room with sub back there... just make sure u sub aint rubbin ur seat when it is hittin hard
Old Jan 3, 2008 | 04:48 PM
95 Jamin Ram
Thanks big ram driver didnt try it yet since it so cold outside
