Drain Plug
Old Jan 1, 2008 | 03:01 PM
Ram2K1's Avatar
Ram2K1
Default Drain Plug
I have heard a lot of ppl talking about a drain plug kit for the tranny pans on Rams. Where do you find these at?
Thx
Old Jan 1, 2008 | 03:26 PM
SilverRam_01's Avatar
SilverRam_01
Default RE: Drain Plug
http://store.summitracing.com/egnsea...5&D=318515
Old Jan 1, 2008 | 09:27 PM
dhvaughan's Avatar
dhvaughan
local napa store. $5-7. you'll need to drill a 1/2" hole in the pan.
be careful of how long the plug kit is, and where you drill the hole.
how to... http://www.pavementsucks.com/tech/trans.php
pics. https://dodgeforum.com/m_911410/mpag.../tm.htm#913800
Old Jan 1, 2008 | 11:06 PM
Ram2K1's Avatar
Ram2K1
ORIGINAL: dhvaughan
Thx for the info. I gotta do that this spring. I'm gonna be towing a Mazda 626 about 1600 miles, so I want to change the filter and fluid. May as well do it while I'm at it... You think it would hurt anything to put some loctite on the nut inside?
Old Jan 1, 2008 | 11:19 PM
dhvaughan's Avatar
dhvaughan
locktite wouldn't hurt. probably a good idea.
the plug kit i bought was overly long up inside the pan, so i sawed about 3/8" off the pipe. the length of this pipe determines how much fluid you drain. it only needs to be as long as the thickness of the pan and the inside locknut.
i changed my fluid last week. it was so nice to drain out most of the fluid and weight.
Old Jan 2, 2008 | 09:22 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: Ram2K1
ORIGINAL: dhvaughan
I hate it when someone uses IM speak (ppl, thx), but anyone who uses Alize for his avatar is someone OK.
Old Jan 2, 2008 | 09:04 PM
Ram2K1's Avatar
Ram2K1
It's just a habit...I use IM at work, and it is much quicker to use short text. Thx 4 the avatar props...
