Fuel pump rebuild...
Old Dec 3, 2004 | 09:05 PM
burnout84's Avatar
burnout84
Default Fuel pump rebuild...
Hello! First off I'm a newbie to Dodgeforum.com...(I've got a 1997 1500 , 4x4 , 5.2 liter engine) A friend of mine gets great results from his Jeep forum so I thought I'd give it a try!!! Does anyone know if I can replace JUST the fuel pump only and not the whole assy(regulator'float...)...any info would be greatly appriciated.
Thanks!! Bob H.
Old Dec 4, 2004 | 01:48 AM
Ramtuff's Avatar
Ramtuff
Default RE: Fuel pump rebuild...
Stop by the dealer and see if you can just get the pump (and filter). I say the dealer, because I wouldn't use an aftermarket pump. I've seen too many aftermarket pumps fail in short order (6K-30K miles instead of the average 120K of a factory pump) to use anything other than factory.
I don't see why you couldn't get just the pump, but you never know with the dealer.
Old Dec 4, 2004 | 02:39 AM
injmopar's Avatar
injmopar
Last year the dealer told me I had to buy the hole sending unit$$$. Think I will buy two aftermarket pumps and put one under the seat . $500 cnd is just a little steep when all you need is a pump.
