another steering box adjustment question
Old Jan 3, 2008 | 02:37 PM
echseman's Avatar
echseman
Default another steering box adjustment question
ok, i know there have been a few other posts, but here's my deal...
before i buy a new agr gear box...
i have slop where my linkage from the steering wheel connects to the gear box. is there any other adjustments i can do to fix this? the adjustment screw tightens my steering, but i still have the slop at the steering wheel. i am puzzled.
Old Jan 3, 2008 | 05:46 PM
TheForce55555's Avatar
TheForce55555
Default RE: another steering box adjustment question
The U joint in your steering shaft is probably coooked. Get a new shaft that goes between the steering box and the steering wheel
Old Jan 3, 2008 | 09:50 PM
echseman's Avatar
echseman
no, the linkage is fine. i already took it all out and inspected it. so anyone think it can be fixed?
Old Jan 3, 2008 | 09:57 PM
TheForce55555
are you talkin about the stub shaft coming out of the steering box ?
Old Jan 3, 2008 | 11:23 PM
dhvaughan's Avatar
dhvaughan
if the slop is in the box, then you see/feel play in the lowest part of the column.
if the box is tight (and the lower shaft), and the wheel wiggles, then the play is in the middle or upper part of the shaft, probably in the u-joint or overlap joint.
here are some possible solutions...
http://www.rocksolidramtrucksteering.com/
http://dodgeram.org/tech/repair/steering.htm
http://dodgeram.info/tech/mods/borgeson/index.html
