plug wires
Old Jan 8, 2008 | 05:31 PM
asimpson97d's Avatar
asimpson97d
Default plug wires
I have an MSD offraod ignition box and blaster ss coil...i was looking for a set of good plug wires and I see everything from 50 ohms/ft resistance to 500 ohms/ft resistance in the hi perf. lines. what have you guys used and what would you suggest for my set-up? (oh yea...its a 426 stroker running 30 lb. injectors and champion truck plugs...as suggested by hughes engines.)
Old Jan 8, 2008 | 05:41 PM
steve05ram360's Avatar
steve05ram360
Default RE: plug wires
msd superconductor 8.5's... my only recommendation.
Old Jan 8, 2008 | 06:53 PM
padodgeram's Avatar
padodgeram
YUPPERS 8.5 MM msd , or MSD 8mm SF wires are a good choice.
Old Jan 8, 2008 | 10:15 PM
Bluebone's Avatar
Bluebone
I'm kinda partial to Magnecor wires, atm. They do cost a little more, though.
Old Jan 9, 2008 | 08:58 AM
asimpson97d
thanks for the input guys...the only reason the cheapies stayed on were because I put them on abouta month before I the motor build...but now I would like to run something better I think...so I just wanted to see what you guys have had good luck with and what worked well. Real world info is ten times better than some sales rep telling me "exactly" what I need! Thanks again
