check engine light wtf!!
Old Jan 9, 2008 | 10:17 AM
sxegrl_n_a_dge's Avatar
sxegrl_n_a_dge
Default RE: check engine light wtf!!
I called the service dept. I was told that the vapor canistervacuum hose was replaced in my truck.A little info. that I'd like to pass on to you,(because this isn't the only vacuum hose),I was told that if this isn't what is wrong with yours that you may want to take it somewhere to have a LEELD test run on it to find out what is causing your check engine light to stay on.
