Wiring harness help
Old Jan 11, 2008 | 03:27 PM
Silver_Dodge's Avatar
Silver_Dodge
Default Wiring harness help
Anyone got the wiring harness that connects to the PCM laying around that you don't need anymore? I'm looking for the three plugs that connect to the PCM.
Old Jan 11, 2008 | 03:33 PM
padodgeram's Avatar
padodgeram
Default RE: Wiring harness help
aright ill bite , what did you do or gonna do that you need it ?? now i have a harness off of a dak. dont know if its the same or not gotta do some R+D on it..
Old Jan 11, 2008 | 04:04 PM
Silver_Dodge
I'm going to mount a second PCM in the engine bay as a spare while I am doing some mpg and performance testing/comparisons. Having a second PCM under the hood will make swapping back and forth a lot easier. Might even just leave it there perminantly as a backup. The reason I want the plugs from a discarded wiring harnes is so I can snip the wires off the plugs, then install the plugs on the PCM that is not in use to protect the PCM's sockets from the elements. So if the plugs from your Dak harness are the same shape and size as a Ram's, that should work fine.
