Dont be stupid.
Old Jan 13, 2008 | 05:29 PM
xskylinedx's Avatar
xskylinedx
Default RE: Dont be stupid.
Ha ha! That damn funny, too bad for your friend though. The funny thing about water fording is that the deeper the water the slower you have to go. lol
Old Jan 13, 2008 | 05:40 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Mudding isn't stupid, people who have no business mudding are stupid.
Old Jan 13, 2008 | 06:17 PM
Sirhilton17's Avatar
Sirhilton17
I Know mudding isnt stupid, but just going through water IMO is kinda easy... not very impressive.
I went through this exact spot the day before.
I go mudding quite a bit, and im slowly working my truck up to be better at it... as my truck sits its probably not to smart to go mudding with.. but I dont care.
Old Jan 13, 2008 | 08:02 PM
dmdenike's Avatar
dmdenike
I went mudding once with this damn fine girl, and had a hell of a time gettin that **** out!
Sorry, pictures where taken from danielle's cell phone...
Old Jan 13, 2008 | 09:02 PM
98DodgeRam1500's Avatar
98DodgeRam1500
I used to go off-roading with this fella, his jeep sucked in a lot of water in a small stream. I towed it out and we let it sit for a while, then hecranked it over and it started, but it wound upblowing a golfball sized hole out the side of the block.
bye-bye motor.
I towed him back to the road side to get towed. he still drives it, but with another 4.0L. I am sure after that he will know to go in a lot slower. oopsie.
I had a F-150 at the time.
Old Jan 13, 2008 | 10:18 PM
JCliffordd's Avatar
JCliffordd
I love 4.0L
I used to be a huge Jeep fan still am
But now its all dodge and i stuck with Mopar
And i used to go through water really fast when i first started wheelin not knowing much
http://img.photobucket.com/albums/v3...o/BBWATER3.jpg
water pouring in my doors
http://img.photobucket.com/albums/v3...o/BBWATER4.jpg
Later on trans shifting hard and not shifting (lot of water in it) did a flush and was fine
Old Jan 14, 2008 | 05:57 AM
tothewall's Avatar
tothewall
ORIGINAL: Cereal Killer
Yeah, as long as you keep it hammered down. You let off you're done.
Jeebus you are full of faulty information dude. You can idle through deep water. As lomg as your engine is running you are good to go. NO need to "keep it hammered"
Old Jan 14, 2008 | 06:35 AM
98DodgeRam1500
ORIGINAL: tothewall
True, so true. Most damage is done when you got the engine wound up. If you are going deep, make sure any inlets are above the water line and go through it at a walking pace. I used to never go any deeper than knee high and I am not that tall. My other off-road buddies would think i was a p***y, but I need to drive my truck to work everyday. I eventually had to tow one of the "wild ones" out of the off-road park. After replacing his motor, he stopped off-roading.
What I need to find is a beater Ram 50, and put some 33's on that and have fun.
Old Jan 14, 2008 | 01:39 PM
EricCartman's Avatar
EricCartman
I dont' think it is nearly as bad as these *** hats... http://www.katu.com/news/weird/13573672.html
Old Jan 14, 2008 | 01:55 PM
92GreenYJ's Avatar
92GreenYJ
i got a decent amount of coin that says he bent or broke a rod. Probably made the problem worse by trying to start it without pulling the plugs and trying to clear the cylinders first. Water does not compress. When I live back east I used to go mudding in my Jeep all the time. there was one pit in particular that at a certain spot was deeper than my hood (was on 33s at the time) granted I had made myself a snorkel but I never had any problems getting my YJ thru it, well, except for the fact that I was running All Terrains at the time so I did get stuck on a few occassions and had to be strapped out.
Mudding and water crossings can indeed be alot of fun, but you MUST take the necessary precautions if you are going to do it. I sealed all my electronics, used di-electric grease on every electrical connection, sealed the dist cap, put in an electric fan (a mechanical one can bend in deep water and take out your radiator) built a snorkel that moved my air intake up above my head where i sit in the drivers seat, and i extended all of my breather hoses as high as i could possibly get them. Another very important thing with this kind of wheeling is to check your fluids regularly, especially your diffs. if they get water in them you can do alot of exspensive damage in a hurry!
