'01 ram strange occurance.
Old Jan 15, 2008 | 06:30 AM
petekf4qoe's Avatar
petekf4qoe
Default RE: '01 ram strange occurance.
I will 3rd that. I had the same thing happen to me. I thought it was the battery so I replaced it but it still ran like crap and would die if I treid to let it idle down to where it should at normal. I did some research and came up with the ECM just had to take a bit to relearn. Just take it out and drive it for a while. Use you left foot to brake and keep it idled up. All will be fine.
Old Jan 15, 2008 | 02:46 PM
Silver_Dodge's Avatar
Silver_Dodge
So did you find out what was wrong lmm600? Did a PCM relearn fix it?
Old Jan 19, 2008 | 01:54 AM
tiny43's Avatar
tiny43
I had the same thing happen to my 99 5.2 sport. My mechanic changed out the idle air control valve runs fine ever since.... tiny
Old Feb 24, 2008 | 10:58 PM
lmm600's Avatar
lmm600
I'm really sorry I didn't respond. Actually forgot. Yes, I guess it had to re-educate itself. Basically a couple days later, probably only 2 or 3 hours running everything seemed fine.
Old Feb 25, 2008 | 12:25 AM
jasonw's Avatar
jasonw
Site Moderator
Our trucks seem to have problems running well at all when the battery is nearly completely drained.
Old Feb 25, 2008 | 03:12 PM
EricCartman's Avatar
EricCartman
My auxilary reverse lights got bumped on one day at work... came out to a nearly dead battery. Tried to jump start it and it started, but it ran like crap. If the revs dropped too far, the truck would die. So... I pulled the battery, went home and threw it on the charger for 5 hours at 25 amps. When I put the battery back it it started and ran just fine.
Cartman
Old Feb 25, 2008 | 06:47 PM
WayneC's Avatar
WayneC
The PCM is VERY sensitive to voltage and won't do its job worth a poop on a dead/dying battery or crappy connections. Anytime you have running/idling problems check the battery/connections 1st...Free is Good!
