tune up
Old Jan 14, 2008 | 04:47 PM
Truck Ram ROD's Avatar
Truck Ram ROD
Default tune up
hey guys my 94 1500 V6 has 101600kms i was just wondering if there was anything that i missed in regards to a tune up i did the air filter, spark plugs, wires, cap,rotor, oil change (every 5000kms) greased the fittings(steering anddrive shaft) is there something else that i would need to do as part of a tune up ?? thanks in advance
Old Jan 14, 2008 | 05:06 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: tune up
You did not perform a tune-up on your vehicle. You serviced some parts. Other than that, sounds fine. Run some injector cleaner every few tanks of gas.
Anyone who wants to argue "tune-up" with me is more than welcome to come over and work on an old VW of mine. We'll adjust the points (the wha--?), the valves (they're not hydraulic), and adjust the timing (no PCM).
Cheers!
Old Jan 14, 2008 | 05:44 PM
IceCreamNazi's Avatar
IceCreamNazi
Default RE: tune up
Here's a link forour American friends to convert that damn Metric to Imperial.
http://onlineconversion.com/length_common.htm
Old Jan 15, 2008 | 03:00 AM
rabbler's Avatar
rabbler
Default RE: tune up
O2 sensor would be a good idea at that mileage.
Old Jan 15, 2008 | 07:49 AM
2 Marks's Avatar
2 Marks
Default RE: tune up
ORIGINAL: VWandDodge
Cheers!
OK, you peaked my interest. Please discuss your idea of a tune-up.It is the next thing on the list. Thanks.
Old Jan 18, 2008 | 06:13 PM
Truck Ram ROD
Default RE: tune up
the phrase "tune up" is more or lessused aspart of a service routine every X kms/miles notnessisarily doing one its just easier to say thats my opinion
as far as the O2 senser could changing it cause the check engine light to comeon and is the PCV valve important to change
thanks again
