Should be easy. ENGINE ID
Old Jan 16, 2008 | 08:04 PM
DOWNinDIXIE's Avatar
DOWNinDIXIE
Default Should be easy. ENGINE ID
Heres the deal, i bought a used 2000 ram 1500 quad cab. The vin # says its a 318, but when you pop the hood, right in front of the radiator says its the 5.9 360. where else on the engine can i find the id. Block, heads etc. ? ant help would be great thx.
Old Jan 16, 2008 | 09:52 PM
WayneC's Avatar
WayneC
Default RE: Should be easy. ENGINE ID
The engine serial number is stamped into a
machined pad located on the left, front corner of the
cylinder block. The 3rd, 4th, and 5th digits (from left to right) are the engine displacement. That's if it's 5.2. The 5.9 should read 5.9
Old Jan 16, 2008 | 10:37 PM
1BigRamaniac's Avatar
1BigRamaniac
What in the VIN made you think it was a 318..."Y" ? 5.9-360 are usually "Z" models. The engine number is usually the8th digit to the right.
X=3.9 EFI
Y=5.2 EFI
Z=5.9 EFI
5=5.9 HDC
8=5.9 Turbo Diesel
Old Jan 17, 2008 | 12:51 PM
DOWNinDIXIE
yes the vin reads "y". its always bad news when these things dont match up. thx for the help.
Old Jan 17, 2008 | 12:59 PM
Silver_Dodge's Avatar
Silver_Dodge
A 5.9 is externally balanced while the 5.2 is internally balanced. So look to see if your engine has a visible vibration/harmonic balancer on the front of the engine off the crankshaft pulley.
