95 ram 1500 with little heat
Old Jan 17, 2008 | 03:29 PM
gofastcrazy's Avatar
gofastcrazy
Default 95 ram 1500 with little heat
it works well when it is 85 or but on 13 degree days i have nothing but coldair.rad is new it is not over heating i have been all over this thing and it is beyond me.can somone give me an idea where to look,and please don't say heater core...i don't want to take the dash out of this thing,but i do have a new dash to put in canue mine is cracked anyway
thanks for the help
Old Jan 17, 2008 | 03:34 PM
SilverRam_01's Avatar
SilverRam_01
Default RE: 95 ram 1500 with little heat
Back-flush the heater core. Cut inlet and outlet hoses in the engine bay, flush it with a garden hose, and then put in-line couplings in to re-attach the hoses. Should clear that right up.
Old Jan 17, 2008 | 03:37 PM
98Woo2500's Avatar
98Woo2500
welcome to the party.......................its an unsolved mystery, however i did flush my radiator and get little more heat. Parts replaced..heater core, radiator, thermostat. I think its an air lock some where in the block.
Old Jan 17, 2008 | 03:39 PM
Ramdude95's Avatar
Ramdude95
Try backflushing the core through the hoses if that doesnt work it could be the blend door isnt opening all the way but it does sound like you need a new core. Mine is almost the same way, it blows kinda warm but not hot, I just havent gotten around to pulling the dash to replace it.
Old Jan 17, 2008 | 04:43 PM
gofastcrazy
good deal thanks i had the core flushed and that change nothing,i have read something about the controles in the dash.what is the issue with them?
Old Jan 17, 2008 | 04:45 PM
gofastcrazy
oh and i forgot,when i am pulling a hill all heat and air go to the defrost when back on level ground it comes back to where ever i had it se.(like in the floor)
Old Jan 17, 2008 | 05:59 PM
Ramdude95's Avatar
Ramdude95
The check valve on the vac line for your hvac is shot dodge replaced the valve with a bigger one which can be obtained at the dealership. It is the one next to the pcv line on your intake it has a little pancake valve on it. As for the controls I have heard of the blend door not opening all the way to the hot side. Check the DIY section up top lots of good stuff plus the complete repair manual for 01 rams but applys to all second gen rams and it cover the blend door problem.
