Starter Question
Old Jan 19, 2008 | 05:11 PM
sitnlopro99gt's Avatar
sitnlopro99gt
Default Starter Question
I have a 94 dodge ram I'm trying to get the starter off I got the two top bolts, but the bottom one which is a stud is not budging...I tired to tap it pry and still nothing yet....is the starter part threaded there to. Any suggestions...I was thinking maybe a stud removal socket tool...I don't have a torch so[/align]
Old Jan 19, 2008 | 05:49 PM
1BigRamaniac's Avatar
1BigRamaniac
Default RE: Starter Question
Breaker bar, and flex it. The only problem I had with my starter was trying to see to put the new one back. You may want to liquid wrench it, wire brush it down, then try again. It should walk on off of there. Are you using a 1/2 in drive ratchet?
Old Jan 19, 2008 | 05:51 PM
dhvaughan's Avatar
dhvaughan
on my 01 there was only 1 bolt on the top. you might have removed an unrelated bell housing or something. back to that later. the stud at the bottom was pressed into the trans/bell housing? and the starter simply slides over it. it did not thread into the starter. mine were torqued down to some superhuman level too. what i had to do was use a heavier 1/2 in drive socket and a long pull handle to break them loose. i actually had more trouble with the top than the bottom, and had to use some long extensions to get the handle out there where i could really pull on it. if you don't have a pull handle, or air wrench that you can get on it, try to put a piece of pipe onto your ratchet handle. use care not to round off the nut, but you're gonna have to put more pull onto it. make sure you're turning it to the left (sorry), but sometimes people get confused laying upside down.
edit. 1BIG beat me to the post, but i would try real hard not to put a flex/u-joint in there because it tends to twist and absorb your pulling torque and slide off the nut.
Old Jan 19, 2008 | 06:02 PM
sitnlopro99gt
yea I was thinking I might have taking off a bellhousing bolt. The two bolts on top where easy after I broke them loose its just the dam bottom stud thats being a b*tch almost like its rust welded in the whole where it won't even budge even after bashing it....grrr thanks for your help so far guys
Old Jan 19, 2008 | 06:07 PM
sitnlopro99gt
ORIGINAL: 1BigRamaniac
Yea I was using a 3/8" socket with a 1/2 drive, I got the nut off the stud on the bottom and everything its just not budging....
Old Jan 19, 2008 | 06:12 PM
dhvaughan's Avatar
dhvaughan
double check the top.. maybe? you removed the wrong bolt. my top one was brutally tight and it was a big sucker, and once the top and bottom were off, the starter was ready to just fall off. careful, its heavy.
Old Jan 19, 2008 | 06:27 PM
sitnlopro99gt
Old Jan 19, 2008 | 06:28 PM
sitnlopro99gt
Don't mind the starter we was havin words but thats the stud that I think is holdin my back because I got the top bolts. Thx guys
Old Jan 19, 2008 | 06:38 PM
dhvaughan's Avatar
dhvaughan
i think someone stole half your starter while you weren't looking. i'd spray pb-blaster or wd40 into every nook and cranny and let it soak awhile, then put a block of wood on that thru-bolt flange and knock the fu** out of it with a hammer. thread the lower nut back on with about 1/4 inch free space so it doesn't fall off when it comes loose.
Old Jan 19, 2008 | 07:04 PM
TheForce55555's Avatar
TheForce55555
wow That sucks, I think you ahve a rear main seal leak on your engine too
