Tire Size
Old Jan 20, 2008 | 01:34 AM
BackWoodz4x4's Avatar
BackWoodz4x4
Default Tire Size
I have a 96 ram 1500 4x4 and i need to get some new tires and i was wondering if 295/75/r16s will fit under it stock?
Old Jan 20, 2008 | 01:53 AM
jasonw's Avatar
jasonw
Site Moderator
Default RE: Tire Size
They should fit, but I believe you will have some rubbing when making sharp turns.
Old Jan 20, 2008 | 02:14 AM
Cereal Killer's Avatar
Cereal Killer
Depends on what your defenition of "fit" is...
They should be fine as long as you know how to drive.
If you're one of those ******* that cranks your steering wheel until the power steering pump whines like it wants to go out then go with something smaller.
Old Jan 20, 2008 | 12:18 PM
BoDuke1987's Avatar
BoDuke1987
you will have to lift the truck 3 inches to clear while turning otherwise you while rub while turning, my 285/75R16 did it, i had to lift my truck 2 inches to clear
