changing the timing chain
My water pump went out on me recently. I figured I was taking so much off I might as well change the valve cover gaskets, change the oil pan gasket, and change the timing chain.
I just wanted to know if there were any tricks, or pain in the butt procedures I should know about. I actually haven't even taken the fan shroud off yet. I know I may run into trouble taking the fan off. If anyone knows any tricks there I would be much obliged. Other than that it seems straight forward. I have the FSM and a Haynes manual plus this site. I bought a double roller chain timing chain set, basiclly the most expensive Autozone had. I noticed Napa had one that came with sprokets. Should I change my sprokets too?
I don't even know if my chain is bad, I just have 140,000 miles and its original. How hard is it to change? It looks easy.
If you were cleaning up your engine and doing a complete tune up, what else would you do?
do everything. you should buy a 'timing set' which will come with sprockets and chain. most all parts stores sell a Cloyes set for about $50. replace front seal in timing cover. also, has your plenum gasket ever been fixed, does it leak.. now's a good time. i'd also do all hoses, belt, look at the bottom rear of your engine - how's the rear main. it can be replaced while the oil pan is off.
some have replaced their timing chain with a 4* advance/retard. i stayed away from that because i was afraid it would lead to problems that i couldn't solve with shade tree methods.
old post, lots of pics. https://dodgeforum.com/m_735291/tm.htm
tip. when i couldn't get the fan off the wp i just unbolted wp and removed wp, fan, and shroud all at once and put the wp in the vise to get it off.
