DODGE 545RFE TRANSMISSION
Old Jan 22, 2008 | 09:54 PM
Junkyard7076's Avatar
Junkyard7076
Default DODGE 545RFE TRANSMISSION
Greetings, my transmission in my 1998 Ram just went up.
I wanted to know if I could put a 545RFE from a newer Ram in it to get the extra overdrive?
Thank you in advance for your help
Old Jan 22, 2008 | 10:58 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: DODGE 545RFE TRANSMISSION
It isn't a direct 1:1 bolt up swap if that's what you're hoping for.
Old Jan 23, 2008 | 01:45 AM
rabbler's Avatar
rabbler
With enough money almost anything is possible.
This would not be any easy swap at all. Custom adapters, mounts and electronics would have to be purchased or fabricated.
Old Jan 23, 2008 | 08:04 AM
IndyRamMan's Avatar
IndyRamMan
Double overdrive? Did i sleep through something?
Old Jan 23, 2008 | 10:16 AM
Junkyard7076
The 545's final two ratios are less than 1:1, doesn't matter everyone is telling me the swap isn't feasable
