oil pressure sensor
Old Dec 10, 2004 | 01:03 PM
RamRod5.2L's Avatar
RamRod5.2L
Default oil pressure sensor
i have a 1995 dodge ram with a 5.2L
when the truck is warm and at idle the oil light sometimes flickers and sometimes stays completely on...when the light stays on my oil pressure guage drops from a little above 40 to 0.
when i bring up the idle just slightly the light goes off and the oil pressure goes back to normal.
have any ideas of what the problem might be
do you know where the two sensors or guages are located or if they are connected
Old Dec 10, 2004 | 01:16 PM
GMsucks's Avatar
GMsucks
Default RE: oil pressure sensor
Step one, Check oil.
Old Dec 10, 2004 | 01:18 PM
RamRod5.2L's Avatar
RamRod5.2L
i check the oil all the time
it has been doing it since i bought it
does it even after oil changes
Old Dec 10, 2004 | 01:19 PM
RamRod5.2L's Avatar
RamRod5.2L
would the type oil have anything to do with
i run pennzoil 10W-30
Old Dec 10, 2004 | 01:54 PM
steve05ram360's Avatar
steve05ram360
your oil pressure sending unit may be going bad, swap it out there pretty cheep. It's located next to the distributor, make sure you clean the wires if there is any oil on the connector.
