Replacing Rear U joint
Old Jan 24, 2008 | 04:57 PM
Eric334's Avatar
Eric334
Default Replacing Rear U joint
I'm going to be replacing the rear U joint on my 2000 ram 4x4. 1 question, I see there are clips on the one that is on my truck now, is that all that holds the u joint in place or is it pressed in ?
Old Jan 24, 2008 | 05:30 PM
TheForce55555's Avatar
TheForce55555
Default RE: Replacing Rear U joint
The clips hold the caps in, i would say they are a tight fit but not pressed fit, because you can change u-joints with a hammer and the right size socket
Old Jan 24, 2008 | 05:32 PM
Eric334's Avatar
Eric334
Cool, Thanks Force
Old Jan 24, 2008 | 05:34 PM
padodgeram's Avatar
padodgeram
you need some needle nose pliers to squeeze it toghter LOOKS LIKE AN L AND I squeeze that part toghter with a flathead screw driver pry at ittill the ring pops out..then get a BFH and a socket bigger then the ujoint stick it on the botton part of the drive shaft to push part of the ujoint thru and do the same on the other side.
Old Jan 24, 2008 | 11:25 PM
dhvaughan's Avatar
dhvaughan
actually the caps are pressed in. its not a real real real tight fit, but it takes either a press or BFH to get them out and some pretty good pressure to get them back in. mine were so tight they didn't want to go back in without too much BFH'ing so i used a dremel with a sanding disk and went around the inside of the yokes a couple times. if you do this don't get carried away, you want it to remain as a tight, tap in, SFH fit.
Old Jan 25, 2008 | 12:06 PM
Eric334's Avatar
Eric334
Cool, thanks guys. Always nice to get help.
