engine miss 96 318
Old Jan 26, 2008 | 01:50 PM
helipilot's Avatar
helipilot
Default engine miss 96 318
Ok heres the problem ive traced it down to the #5 injector wire or so it seems i can pull the wire off the injector and no change #7 pull wire motor changed i swap #5 For # 7 #5 works #7 doesnt so i check wire with ohm meter from end to end both +&- all good my question is do you think it could be the computer not sending a pulse to that wire i do get power from the wire but is it not the neg wire that the computer controls the pulse with?
