rotor off, now the bearings
Old Jan 26, 2008 | 08:04 PM
mailman's Avatar
mailman
Default rotor off, now the bearings
Got the rotor off, bought new rotor/hub assembly, now how do I get the backside bearing out--or do I need to buy a new set? BTW, this new rotor has a ring gear in the backside, whereas the original doesn't. Is this the right one, and what is the gear for? 1996 Ram 1500
Old Jan 26, 2008 | 08:55 PM
Scottr1110's Avatar
Scottr1110
Default RE: rotor off, now the bearings
is it a 4x4 or 2wd what do you mean by backside bearing and the ring gear would be for 4 wheel abs which you dont have dont think its going to matter if you put it on the ring gear wont get used
Old Jan 26, 2008 | 09:39 PM
mailman's Avatar
mailman
2WD, and should have said the inner bearing. I thought that perhaps the bearings came installed.
